Let Robots Truly See
Arducam TrueSight Robotics Vision Series
Built for machine vision, robotics, and real-time decision-making, the TrueSight Series offers a complete lineup of global shutter cameras — including single-camera modules, synchronized stereo kits, and multi-camera systems supporting up to 8 sensors.
With features like onboard ISP, hardware-level synchronization, and a GMSL-enabled long-distance extension kit, TrueSight delivers precision, flexibility, and reliable performance — giving your robots the ability to see clearly, act faster, and understand the world around them.
Purpose-Built for Robotic Vision
From navigation and SLAM to depth sensing and object tracking, modern robots demand more from their cameras — and the TrueSight Series delivers on every front.
It’s designed to meet the core challenges of robotic vision systems.
Motion-freezing accuracy
with color global shutter sensors
Real-time responsiveness
with onboard image processing
Spatial awareness
through synchronized stereo and multi-camera configurations
Reliable connectivity
even across moving parts and long distances, via GMSL extension support
Precision
Global Shutter Sensors
True global shutter sensors eliminate motion blur and rolling artifacts, capturing sharp, undistorted images — even in fast-moving or vibration-heavy environments.
Processing
Onboard ISP
Built-in ISP handles exposure, white balance, noise reduction, and more — offloading the compute platform and delivering optimized, ready-to-use images.
Stereo
Synchronized Dual-Cam Kits
Dual-camera kits with hardware-level synchronization provide perfectly timed frames for accurate depth sensing, 3D mapping, and stereo AI vision.
Scalability
Expandable Multi-Camera System
Our multi-camera system supports up to 8 cameras (via 4-channel board), enabling surround view, multi-angle tracking, or robot-wide vision.
Reach
GMSL Extension Support
With ADI GMSL2 technology, TrueSight enables high-speed, low-noise video transmission over long, single-cable connections — ideal for mobile and modular designs.
Integration
Compact & Embedded-Friendly
Designed for integration, TrueSight modules offer a minimal footprint, MIPI or USB, and compatibility with popular platforms like Raspberry Pi, Jetson, and more.
Flexibility
Variable Baseline
In TrueSight stereo kits, the distance between the two global shutter cameras — the baseline — can be physically adjusted to suit your specific depth range and accuracy needs.
Applications That Demand TrueSight
Whether you’re building a mobile robot, a vision-guided arm, or an AI-powered sensor system, the TrueSight Robotics Vision Series delivers the imaging performance and reliability your project needs.
Here’s where TrueSight makes a real difference
Humanoid Robots
Human-like motion demands accurate vision. TrueSight enables precise hand-eye coordination, facial/object tracking, and fast stereo processing — with zero rolling shutter distortion.
Underwater Cleaning Robots
TrueSight delivers clear, flicker-free vision for robots operating below the surface, ensuring reliable navigation and debris detection without motion blur or lighting distortion.
Factory Automation
For pick-and-place arms, conveyor inspection, or part recognition, TrueSight’s low-latency vision and Jetson integration help maintain real-time speed and accuracy on the line.
Service Robots
Home and commercial robots rely on stable, flicker-free, and distortion-free video to recognize faces, gestures, and obstacles — all handled gracefully by TrueSight’s ISP and global shutter.
Warehouse AMRs
Whether navigating aisles or transporting loads, AMRs benefit from long-range vision via GMSL2, and multi-cam support for 360° awareness and precise localization.
Need to distinguish crops from weeds in the field? TrueSight’s sharp, global-shutter vision supports AI-driven plant classification — even with fast camera movement and harsh lighting.
Choose Your TrueSight Camera
The TrueSight Series includes a range of options — from single-sensor modules to stereo kits and scalable multi-camera systems. All models share core benefits: global shutter, onboard ISP, and robotics-ready design.
TrueSight Series Product Lineup
Dual-Camera Kits (Stereo Vision)
Purpose-built for depth sensing, SLAM, and stereo AI applications, these kits provide hardware-synced global shutter sensors with onboard ISP. Perfect for robotics perception.
TrueSight Stereo-GMSL
2.3MP Global Shutter Dual-Camera Bundle Kit for Jetson Orin Nano/NX
TrueSight Stereo-USB3
USB3.0 UVC Global Shutter Dual-Camera Kit
TrueSight Stereo-USB2
USB2.0 UVC Global Shutter Dual-Camera Kit
TrueSight Stereo-Jetson
Sync Stereo 2.3MP Global Shutter Dual-Camera Kit for Jetson
Single Camera Modules
For general robotics and embedded vision use, these compact modules deliver global shutter accuracy with onboard ISP, ideal for arms, tracking, or mobile bots.
TrueSight GS-USB2
USB2.0 UVC Camera Module, 2.3MP Global Shutter
TrueSight GS-Jetson
Global Shutter Camera Module for Jetson Orin Nano/NX
Multi-Camera System
Designed for robot-wide vision, surround view, and complex perception setups. This 4-channel kit supports up to 8 synchronized global shutter cameras, with GMSL2 for long-range transmission.
TrueSight MultiCam 8x
4-Channel Dual-Camera Bundle Kit for Jetson Orin Nano/NX
TrueSight Series at a Glance
From USB to GMSL, single to multi-cam, each TrueSight model is optimized for different robotic needs. Use this chart to compare core specs and choose the best fit for your project.
Built with Industry Leaders
The TrueSight Series is the result of close collaboration between Arducam and leading technology partners — combining our embedded camera expertise with world-class components in imaging, control, transmission, and edge AI.
While Jetson modules are not included, many TrueSight kits are purpose-built for NVIDIA Jetson Orin Nano/NX, and we work closely with NVIDIA to ensure seamless hardware and software integration with their edge AI platforms.
We partner with onsemi to integrate high-performance global shutter sensors designed for robotics and industrial automation.
TrueSight supports 15-meter long-distance video transmission using ADI’s GMSL2 SerDes technology, ensuring robust performance even on mobile or modular robots.
We collaborate with Omnivision to offer compact global shutter sensors ideal for space-constrained and battery-powered robotics platforms.
Through our work with ams OSRAM, we provide access to specialized global shutter sensors optimized for fast motion capture and challenging lighting conditions.
Precise multi-camera synchronization, signal routing, and low-power real-time processing is made possible with Lattice FPGAs, built into many TrueSight models.
Need Something Custom? We’ve Got You Covered
We understand that no two robotics projects are exactly alike — that’s why Arducam offers customization services tailored to your specific hardware, software, and system requirements. Whether you need a different lens, a unique form factor, custom synchronization behavior, or firmware tuning — we can help you build the perfect imaging solution for your application.
